Mar 9, 2017 2:28 PM UTC
Unable to use ActionListeners in Java
I am attempting to create some helper plugins for our authors using Java. I made a post earlier this morning outlining that I cannot get 6.0 to see my custom/classes. On another machine I have 6.1, and it does read the custom/classes as advertised. Now I have come to another issue. It seems that the JRE Arbortext uses does not include the awt.event classes? In both my own developed test app, as well as the sample 'TagContent' app, I get this exception in the JavaConsole:
Line 95 is at the bottom of this image:
This is the error when attempting to run the sample provided by PTC. If I comment out the lines that call for 'ActionListener' I get no errors. Not sure what the 'correct' way is to use a button in Java Swing within Arbortext.
Any help is much appreciated.
Thank you,
T.F.
