Nov 30, 2011 8:19 PM UTC
Unbalanced Tag Error in FOSI Usetext
I'm trying to add metadata and bookmarks when publishing a document to PDF using a FOSI stylesheet. I've added a usetext to the root tag however everytime I try to apply the FOSI changes I receive a "Generated text contains unbalanced tags, i.e. begin tags without ends, or vice versa. Cannot insert."
I would appreciate any help you could offer,
FOSI Code:
<e-i-c gi="comdtinst">
<charlist>
<usetext source="!&lt;atidmd:DocumentMetaData source="atend"&gt;&lt;/atidmd:DocumentMetaData&gt;!" placemnt="before"></usetext>
<usetext source="!&lt;atidmd:DocumentMetaData"><atidmd:outline><atidmd:bookmark><atidmd:title>Book Title</atidmd:title></atidmd:bookmark></atidmd:outline></atidmd:documentmetadata>!" placemnt="after"></usetext>
</charlist>
</e-i-c>
    Dec 1, 2011 3:50 PM UTC
    You add the xmlns attribute to the root element of your XML document. It's nowhere in the FOSI.
    And is the namespace declared in the document on some ancestor element (root element would cover everything, of course) of the location where the <usetext> is trying to make the insertion?
    I know this sounds very step-by-step and basic, but the devil is always in the details.
    Steve Thompson
    +1(316)977-0515
    Dec 1, 2011 4:22 PM UTC
    THANK YOU STEVE!!! That did it. It all compiled as expected. Now on to more complicated endeavors.
    Sarah
    Dec 1, 2011 4:23 PM UTC
    Thank you too David!!
    I appreciate all the responses and help!!
