Use a Different Stylesheet with PDMLink Publishing
Is it possible to use a different stylesheet when generating a PDF for PDMlink vs. generating the PDF from other sources?
How would you recommend to accomplish this? Using 5.4 and PE.
Thanks in advance.
    byork17-PeridotAuthor
    So I have a related question.
    I need to know how or if I can switch a stylesheet after the job has already been submitted to the Publishing Engine. I suspect I can by using the composepreprocesshook, but I am unsure how.
    Thanks in advance!
