Sep 24, 2015 7:56 PM UTC
Using an attribute value to output a graphic in FOSI
We are using Arbortext Editor 6.1 M020. We are beginning to use MathML instead of ATIMath. We are using MathFlow 2.0b for Arbortext as our equation editor. I am creating a FOSI that will allow our copyeditors to produce a very lightly formatted manuscript (PS or PDF) for internal QC purposes. An example of an equation is:
<disp-formula id="df1" medium="all">
     <mml:math altimg="C:\Users\rschoen\AppData\Local\Temp\MMLIMG2768143.png" display="block"> ...
     </mml:math>
</disp-formula>
Since MathFlow has already created an image of the equation for us, I would like to have the FOSI use that to produce the output manuscript. I would like to grab the value of the altimg attribute of the mml:math tag and have that image displayed in the output but I'm not sure whether that is possible. And, if it is possible, how to go about doing it.
Can anyone help?
Rick Schoen
Sep 25, 2015 7:26 PM UTC
Hi Rick,
Does the DTD have one or more elements for graphics? If so, is the file name or entity reference method used for specifying the graphic file name?
Suzanne Napoleon
Sep 25, 2015 8:06 PM UTC
Hi Suzanne,
We have 2 elements for graphics: graphic and inline-graphic. For both elements, we use a file name reference method for specifying the graphic file name:
     <graphic xlink:href="fg15.eps"></graphic>
or
     <inline-graphic xlink:href="ig1.tiff"></inline-graphic>
Rick
Nov 13, 2015 5:27 PM UTC
Rick,
    Did the answers provided resolve your issue?
If so, could you indicate which one, or write how you resolved the issue and mark it as correct, so that the community can review this thread and see what is the correct answer?
