Aug 14, 2014 2:11 PM UTC
Using ATE Editor to creatae PostScript files - FOSI features supported?
I am using the ArborText Editor (v. 5.4) startup command to print my XML documents to PostScript files.This process uses our standard Editor FOSI. I would like touse certain FOSI features like"keeps" to control the breaking ofelements over page boundaries. Will this work using my Editor FOSI?
John
    Aug 14, 2014 11:00 PM UTC
    Yes, you can code Keeps in the FOSI. The Keeps category does not apply to the Edit window. One thing: in the tagged FOSI editor, select Edit->Stylesheet Identification and make sure Print/PDF is checked.
