Jul 22, 2011 12:40 PM UTC
Using macros to draw items. How (and where) do you set line type and fill.
I'm getting bogged down trying to do something simple.
I'm trying to draw items in a macro, some in "No Pen", some with "Thick" lines and some with white fill
I'm using rectangle, but am having problems both setting the fill type (can't see how this is set) and in getting the pen type to work.
The example below is the simplest way I can show the problem pen problem.
macro testrectangle
Set active pen "No Pen"
create rectangle 9 9 9 19 19 19 19 9
Set active pen "Thick"
create rectangle 10 10 10 20 20 20 20 10
end macro
What I think it should do is draw 1 rectangle in "No Pen" and the 2nd rectangle in "Thick", but what it does is draw both rectangles in thick and thin.
Do rectangles work differently to lines - can't you set the linetype and fill for them in a macro?
    Jul 22, 2011 2:01 PM UTC
    Try this.
    Macro Test_Rectangle
    Select None
    Create Rectangle 9 9 9 19 19 19 19 9
    Set Active Pen "No Pen"
    Select None
    Create Rectangle 10 10 10 20 20 20 20 10
    Select None
    End macro
    A couple things. When you use set active pen, it not only changes your active pen but also whatever you have selected. Use this to your advantage. Draw the object and then apply the pen.
    In your original sample, both pens would be the same because you draw one, change the pen which changes the one you just drew, and then you draw a new one. Use select none a lot.
    In regards to the thick/thin, it appears to be a default. You could like make a call to shut off drawing the thick/thin line (check your preferences for this setting). I'm guessing (Haven't tested) that this should resolve it.
    TimSharp1-VisitorAuthor
    Jul 22, 2011 2:30 PM UTC
    Thanks Trevor, helpful as always.
    Trouble is that to make my example as simple as possible, I removed a lot of the coding. If I put that back in, along with the "select none"'s that were already there, it still doesn't work.
    I start a group before drawing the first bit of geometry, ending it after drawing the last bit. I guess the "select none" command is being ignored if it's inside the "start group" command:
    start group
    Select None
    Select None
    Select None
    end group
    end macro
    Suppose I'll have to add some infos to each bit of geometry and then select them by the infos later to group them. I wonder why do they make things so difficult in IML?
    Jul 22, 2011 2:37 PM UTC
    Ah, groups. Yes, I've experimented with those and despised that function. In that case, your approach of selecting after and then grouping likely is the best option. Good luck.
    Jul 22, 2011 4:32 PM UTC
    Hi tim,
    See whether this will be Helpful.........
    Macro dsf
    Set Active Pen "Thin"
    start group
    Select None
    end group
    UNGROUP SELECTION deep
    Define el as element
    el = activeDoc.firstSelectedElement
    el.Rect.segments[1].pen = "Thin"
    el.Rect.segments[2].pen = "Thin"
    el.Rect.segments[3].pen = "Thin"
    el.Rect.segments[4].pen = "Thin"
    cut
    PASTE same_position
    Group selection
    End macro
    Jul 22, 2011 4:42 PM UTC
    I think after ungrouping you can provide specific attribute values and then select using the attribute values,
    apply thin, thick,
    then Group
    Jul 22, 2011 4:50 PM UTC
    Some Changes
    Macro dsf
    start group
    Select None
    end group
    el = el.nextSelectedElement
    el.Rect.segments[1].pen = "Thick"
    el.Rect.segments[2].pen = "Thick"
    el.Rect.segments[3].pen = "Thick"
    el.Rect.segments[4].pen = "Thick"
    cut
    PASTE same_position
    Group selection
    end macro
