Oct 28, 2014 5:40 PM UTC
using xincludes
Does anyone know how to collapse all file references quickly when using a document containing a bunch of xincludes to reference other docs, but allow the file name to display?
Normally I use entities, but AE 6.0M060 crashes when the parent document is open and a child is edited. Later iterations of 6.0 have the same problem. Work around is using xincludes but all children are expanded when the parent is opened, making a really long document to scroll through.
TimPhelpsAnswer
Oct 28, 2014 5:57 PM UTC
If you highlight the xinclude and use ctrl+shift+a_number does that get you a better view?
ctrl+shift+1 collapses the selected to the children of the element
ctrl+shift+2 collapses the selected to the grand-children of the element
ctrl+shilf+3 collapses the selected to the great-grand-children
etc.
TimPhelps12-AmethystAnswer
etc.
Nov 14, 2014 5:28 PM UTC
Hi Ashley. Just checking to see if Tim's response was what you were looking for, or if you had any follow-up questions the Community can help with. Let us know!
Nov 16, 2014 9:21 PM UTC
Yes the solution provided by Tim gets me a better view.
Thank you very much this tips is very helpful moving forward.
