Mar 16, 2015 8:16 PM UTC
viewing final index markup
I'm trying to troubleshoot some index issues and would like to be able to view the final index markup in the edit window.
I followed the instructions in the Help file for this and I can see the preliminary index markup, but the _final pseudo tags contain no content. Do I need to code something extra special in my fosi in order to see the final index generated text?
KM
    Mar 16, 2015 9:37 PM UTC
    Hi Kim,
    Does the final index appear in Preview?
    Suzanne
    kmccain1-VisitorAuthor
    Mar 17, 2015 12:19 PM UTC
    Suzanne,
    If you mean when doing a Print Preview with composer, yes, the index does appear in its final sorted version. Unfortunately, it still isn't sorted correctly, and there are some odd extra spaces, which is one reason I wanted to try looking at the final markup to see if I could figure out what is going on.
    Kim
    Mar 17, 2015 4:51 PM UTC
    Re: "but the _final pseudo tags contain no content" in your earlier emial, does this mean you see just <_final> in the Edit window, or do you see other pseudo tags as well?
    To: -
    Sent: Monday, March 16, 2015 4:16 PM
    Subject: [adepters] - viewing final index markup
    Hi,I'm trying to troubleshoot some index issues and would like to be able to view the final index markup in the edit window.I followed the instructions in the Help file for this and I can see the preliminary index markup, but the _final pseudo tags contain no content. Do I need to code something extra special in my fosi in order to see the final index generated text?Thanks,KM
    Site Links: View post online View mailing list online Start new thread via email Unsubscribe from this mailing list Manage your subscription
    Use of this email content is governed by the terms of service at:
    Mar 17, 2015 5:36 PM UTC
    I see a lot of tags:
    <num-index.psu*><usetext userule="2" id="0" fid="65535"><_final><_prelim></tiv>
    <ixpt*>...</ixpt*><ixsub1*>..</ixsub1><ixpgstr*>...</ixpgstr*>
    ----many of these until the end----
    </num-index.psu*>
    All the preliminary index markup seems to be there in its unsorted order. I can't see the final index until I do a Preview or Compose it.
    Maybe I'm doing something fundamentally wrong in the FOSI while producing the index. I inherited the FOSI and I'm trying to add functionality that was missing, but most of the index stuff was already there, just not picking up all the part nos. and in the wrong sort order so I'm trying to fix those things.
    Mar 17, 2015 6:22 PM UTC
    Kim,
    Have you tried exporting the markup to a file via the setting userule="1"?
    That's a technique used when debugging indexes to look at index markup.
    You can do this by changing a line in your FOSI like (YMMV)
    <usetext source="index.app" userule="2">
    to
    <usetext source="index.app" userule="1">
    The output will then go a file <eic-name>.exp
    --Jack
    LSI, Inc
    Jacksonville, FL
    Mar 17, 2015 6:30 PM UTC
    If you are seeing gentext tags and the preliminary index, you should be seeing the final index. Are you getting any error messages? Be sure Preferences are set to display all warnings, messages, and errors. An index-related message often includes a link to the document.
    Note that index sorting is alphabetical not numerical. The <ixkey> preliminary index pseudo-element is needed for correct numerical sorting. This is discussed in Chapter 5 of my book at
    Mar 17, 2015 7:27 PM UTC
    For the record, the .exp file shows preliminary index markup with final page numbers.
    Mar 17, 2015 7:34 PM UTC
    OK. I am seeing the following errors:
    [A12550] ERROR (indexing): Can't use page string for page key; may need explicit key.
    [A12534] ERROR: (indexing) No index records found in preliminary index.
    But I am seeing the preliminary index markup in the document - like this:
    <ixpt>9740-0183</ixpt><ixsub1>1-</ixsub1><ixpgstr>1-00</ixpgstr>
    <ixpt>9740001-E20</ixpt><ixsub1>1-1</ixsub1><ixpgstr>1-00</ixpgstr>
    <ixpt>9740001-E301</ixpt><ixsub1>1-2</ixsub1><ixpgstr>1-00</ixpgstr>
    I did try changing userule to 1 and exporting it to an external file. I get the preliminary index markup there as well. But when I compose it, I do get the sorted index and the page strings are there ..so it's doing something, somewhere, with the preliminary markup...
    Mar 17, 2015 7:51 PM UTC
    The Help info and my book contain a list of index-related error messages, including these, and what to do about them. I suggest focusing first on the error message about needing an explicit key.
    Mar 18, 2015 12:24 PM UTC
    Suzanne,
    Thanks. I fixed the page string error and can now see the final index markup in the Edit window. I've figured out why I'm getting some extra spacing in the output, too. But I still haven't gotten the sort problem figured out.
    I need all the alpha groups before the numerical groups in this index, but if I use a custom collation file it will change the sort order for all indexes, won't it? while I just want to change the part number index, but still be able to have a normal alphabetic glossary if I need it. or am I mistaken?
    Kim
