Jul 2, 2025 9:02 PM UTC
Warnings reported on existing document after upgrade to Editor 8.3.1.0
<Record date="Wed Jul 2 12:34:12 2025" millis="1751474052" msgid="A28105" severity="warning" suppress="0">
<Level>WARNING</Level>
<Heading>C:\xml_environment\Doctypes\axdocbook\axdocbook.fos</Heading>
<Message linkname="FOSI Editor" command="_showids::sx_edit_oid(41,'(1298,1,41)',0,1)">&lt;rsrcdesc | {recto,verso,blank}pg {dflt}layoutconfig> refers to an entity "uniform" (Public ID="-//ArborText//NONSGML ATI Layout config. uniform//EN", System ID="", Type="NDATA", Notation="lcf") which could not be resolved to a valid path. A catalog entry for this entity may be missing or the entity declaration may be incorrect. Expect default behavior for this entity reference.</Message>
I have searched through our files for an entity "uniform" and cannot find any reference.  Appreciate some troubleshooting help here.
Emeritus
Jul 10, 2025 4:41 AM UTC
Hi @RO_10609401,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
Jul 10, 2025 8:20 AM UTC
Dear Customer,
Hope you're doing well. Please refer the below articles that can help you resolving this issue.
https://www.ptc.com/en/support/article/CS326297
https://www.ptc.com/en/support/article/CS285632
Also check, if the fosi file has the same folder hierarchy in the upgraded one compared to pre-upgraded folder directory.
Manpreet Singh
Emeritus
Jul 14, 2025 4:21 AM UTC
Hello @RO_10609401,
It looks like you have a response from a support expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
