Apr 12, 2021 7:33 PM UTC
Webinar: XML Saves Lives presented by Single-Sourcing Solutions | May 4th at 1PM ET
https://ptc.zoom.us/webinar/register/WN_XHp05BVhRgyfm3ls1wrjpQ
In this session, we discuss some of the factors that compel forward-focused companies and consultants to make the leap to XML. You will learn what XML is, how it works, and how you can move from the trap that is desktop publishing into a flexible, dynamic structured authoring environment with ease. By the end of our talk, you will be able to comfortably answer the important questions: Why should you make the transition? How can you make the transition? And, when is the right time to make the leap?
Apr 22, 2021 7:20 PM UTC
This promises to be a great webinar - register today!
XML Saves Lives Webinar – May 4
