bfriesen
18-Opal
Jun 7, 2019 4:02 PM UTC
Which file determines what elements are valid in a ditamap
Good morning I would like to know what determines which elements are valid in a ditamap. I would also know how to modify this file.
Bryon
Jun 8, 2019 11:17 AM UTC
You don't want to mess with that, look into DITA specialization instead. It is fiddly but works well once you have it figured out.
bfriesen
bfriesen18-OpalAuthor
18-Opal
Jun 10, 2019 12:57 PM UTC
Thanks Gareth. The reason I ask is that appendix was removed from ditamap as a vailid element. In the default style sheet there is still an element that is labeled appendix. If I turn off context rules it is not even in the list of options. So my thought was to add the appendix element back to ditamap. I will look at dita specialization, I expect this is something that would be easily handled by it.
Bryon
