Apr 15, 2016 7:47 AM UTC
Which one is better? IsoDraw and Creo Illustrate
I am working as an technical illustrator. I installed some softwares as following.
  • Autodesk Inventor
  • PTC Creo Parametric
  • PTC IsoDraw CADprocess
  • CorelDraw
  • Windchill
  • Arbotext Editor
I have two working process
  • Open 3D model in Inventor  > Create 2D drawing as CAD file > Open the drawing in CorelDraw > Modify the drawing and export it to SVG
  • Open 3D model in IsoDraw > Create 2D drawing as CGM > Open CGM in CorelDraw > Modify the drawing and export it to SVG
I upload SVG to Windchill one by one.I think it will be easy to use if there is a link between Isodraw and Windchill.
There are two choices for me. IsoDraw and Creo Illustrate. I want to know which one is better.
Thanks.
br, Lily
VladimirNAnswer
Apr 15, 2016 2:31 PM UTC
To say briefly - these software products are designed for a slightly different purpose:
  • Arbortext IsoDraw - for creating 2D technical illustration (it has a good functionality for these purposes);
  • Creo Illustrate - for 3D technical illustration (including 3D animation).
Or you mean - better for connecting with Windchill PDM?
P.S. But apparently the functionality of both programs eventually merged into one new software.
VladimirN24-Ruby IVAnswer
lguo1-VisitorAuthor
Apr 17, 2016 2:46 AM UTC
thank you very much.
I think they are both easy to connect Windchill PDM.
Apr 23, 2016 11:43 PM UTC
Did you find the responses helpful? If so, could you let the community know by selecting Correct for the answer that assisted you most?
Thank you.
