Oct 27, 2016 12:40 PM UTC
Will Arbortext Editor supports HTTPS to communicate from external CMS systems?
We have document management system to manage documents, for editing document, we would need to use Arbortext editor using https protocal.
Will Arbortext Editor supports https for external CMS systems?
Regards
Katama
    Nov 2, 2016 10:20 PM UTC
    I would say: That's up to you. Unless your CMS is one of the supported ones, you will need to build your own adapter.  How you implement communication is up to you and how you code the adapter.
