Jun 21, 2016 7:59 AM UTC
With an ACL function, how to add a menu when Arbortex Editor starts
I tried to add a menu using an ACL function in a script file init.acl (C:\Program Files\PTC\Arbortext Editor\custom\init\init.acl) but the menu is not loaded.
I want the menu to load when Arbortext Editor is starting.
Script:
function load_menu() {}
mad -before ".File.Close" "Test" -cmd {};
load_menu()
Regards
Can you help me?
David
Jun 21, 2016 8:29 AM UTC
Hi David,
Here is a simple example for adding a menu after the Help menu in Editor.
An important note is to put your load scripts into the /init folder within your custom folders. Any scripts in this folder load when Editor opens. You also need to use a menuloadhook to load the menu function.
function initMenus(){
menu_add -menu .Help "MyMenu";
menu_add .MyMenu. "MyCommand" -cmd {myFunction()}
add_hook("menuloadhook","initMenus");
Hope that helps!
Hi David,
Hope that helps!
dgopois13-AquamarineAuthor
Jun 21, 2016 8:37 AM UTC
Hi Jeff,
Thank you for your help.
David
