Jul 30, 2014 12:19 AM UTC
writing advanced PDF metadata (Copyright, for example)?
Hiya,
Has anyone had any success populating the advanced metadata (document
properties) in PDFs?
I am able to set:
Title
Author
Subject
Keywords
I can't set:
Author Title
Description Writer
Copyright Status
Copyright Notice
Copyright Info URL
I'm mostly interested in the last three.
(If you search the archives for atidmd you will probably see a discussion
in which Susanne shared part of her book that relates to this, but like the
PTC documentation, those advanced properties are not addressed.)
I don't know what the correct Key names are for them. They don't work
as-is. Removing the space or replacing it with an underscore doesn't work.
Replacing it with %20 crashes the formatting engine (whee haw!).
Paul Nagai
    Jul 30, 2014 2:03 AM UTC
    I think current APP releases are able to set these via the XMP metadata feature. I assume you're on FOSI though. The easiest way might be via post-process of the PDF? A basic PDF tool such as PDFBox should do the job.
    // Gareth Oakes
    // Chief Architect, GPSL
    // www.gpsl.co
    naglists1-VisitorAuthor
    Jul 30, 2014 5:12 PM UTC
    Hi Clay,
    Thanks for the info. That is (more or less) the FOSI coding I tested. And,
    you're right. Those values show up on the Custom Properties tab. I didn't
    think to look there.
    I'm not sure the authors / legal folks will be OK with copyright info
    buried in the Custom properties tab, though. I'd like the ability to update
    the Additional Metadata dialog. (Choose File > Properties > Description tab
    > Additional Metadata button.) That dialog has three fields dedicated to
    copyright data:
    Copyright Status (a drop down supporting Unknown, Copyrighted, Public
    Domain)
    Copyright Notice (a text area)
    Copyright Info URL (a text field)
    And I'm viewing in Adobe Reader X (10.1.0).
    Probably time for a case to see if support knows how (or can confirm it
    isn't possible).
    Jul 30, 2014 9:53 PM UTC
    Ah ... I have Adobe Reader X *Pro*. Sorry. Forgot the Pro part. But that
    raises a good point. We'll need to be aware that what displays will be
    dependent on reader technology. (I love those matrices. NOT!)
    On Wed, Jul 30, 2014 at 10:37 AM, Clay Helberg <chelberg@terraxml.com>
    wrote:
    > Paul--
    > Are you sure you're using Adobe Reader X to see that Additional Metadata
    > dialog? What you describe matches what I see in PDFXchange, but in Adobe
    > Reader X (10.1.1), I don't see an "Additional Metadata" button:
    > Anyway, if you find out a way to do what you are after with FOSI, I hope
    > you'll post the solution so we can all see how it works. I agree that this
    > is something that could use better documentation, both on the Arbortext
    > side and on the Adobe side.
    > --Clay
    > *From:* Paul Nagai [
    > <atidmd:docview mode="bookmarks" fit="fitPage" destination="">
    > </atidmd:docview>
    > </atidmd:documentmetadata>!' placemnt="before"></usetext>
    > <usetext<br/>>
    > source="!<atidmd:documentmetadata>
    > <atidmd:docinfo>
    > <atidmd:entry>
    > <atidmd:key>Title</atidmd:key><atidmd:value>Moby
    > Dick</atidmd:value>
    > </atidmd:entry>
    > <atidmd:entry>
    > <atidmd:key>Author Title</atidmd:key><atidmd:value>This
    > should be the Author Title</atidmd:value>
    > </atidmd:entry>
    > <atidmd:entry>
    > <atidmd:key>Copyright URL</atidmd:key><atidmd:value>
    ">http://www.copyright.com</atidmd:value>
    > </atidmd:entry>
    > <atidmd:entry>
    > Status</atidmd:key><atidmd:value>Copyrighted</atidmd:value>
    > </atidmd:entry>
    > </atidmd:docinfo>
    > </atidmd:documentmetadata>!" placemnt="after"></usetext>
    > But, if you are using PDFXchange, it will not report non-standard metadata
    > fields, unless they are defined in the XMP format that Gareth mentioned.
    > So, to set the copyright fields (and have PDFXchange map them correctly),
    > you would need something like this inserted into your PDF stream:
    > /Type /Metadata
    > /Length 3336
    > /Subtype /XML
    > stream
    > >¿" id="W5M0MpCehiHzreSzNTczkc9d"?>
    > <x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP" core=" 4.1.1&quot;=">
    > <rdf:rdf xmlns:rdf="&lt;br"/>>
    > <rdf:description rdf:about=""&lt;br"/>>
    > xmlns:xapRights="
    > <xaprights:marked>True</xaprights:marked>
    > <xaprights:webstatement>
    > ">http://www.manualcopyright.com</xaprights:webstatement>
    > </rdf:description>
    > </rdf:rdf>
    > </x:xmpmeta>
    > You would probably also need this kind of format if you are trying to
    > enable any automatic processing of copyright status.
    > I don't know if FOSI can produce XMP metadata, in fact I'd be surprised if
    > it can. But maybe Susan or Trudy knows some secret FOSI sauce to make that
    > work.
    > --Clay
    Aug 5, 2014 6:24 PM UTC
    PTC confirms that Arbortext doesn't currently support writing XMP metadata
    to PDF output by Editor or PE. I submitted a feature request (technically,
    a Product Idea) here:
    >> --Clay
    >> </atidmd:docview>
    >> <usetext<br/>>>
    >> <atidmd:docinfo>
    >> <atidmd:entry>
    >> Dick</atidmd:value>
    >> </atidmd:entry>
    >> <atidmd:entry>
    >> </atidmd:entry>
    >> <atidmd:entry>
    >> </atidmd:entry>
    >> <atidmd:entry>
    >> </atidmd:entry>
    >> </atidmd:docinfo>
    >> metadata fields, unless they are defined in the XMP format that Gareth
    >> mentioned. So, to set the copyright fields (and have PDFXchange map them
    >> correctly), you would need something like this inserted into your PDF
    >> stream:
    >> /Type /Metadata
    >> /Length 3336
    >> /Subtype /XML
    >> stream
    >> <rdf:rdf xmlns:rdf="&lt;br"/>>>
    >> <rdf:description rdf:about=""&lt;br"/>>>
    >> xmlns:xapRights="
    >> </rdf:description>
    >> </rdf:rdf>
    >> </x:xmpmeta>
    >> if it can. But maybe Susan or Trudy knows some secret FOSI sauce to make
    >> that work.
    >> --Clay
