XPATH help
<listitem><para>text
<randomlist>
<I am here<para>text</para></listitem>
<listitem><para>text</para></listitem>
</randomlist>
</para></listitem>
</randomlist>
I'm trying to test if the top randomList has listItemPrefix="pf01" and ignore it if it doesn't have the attribute set
This doesn't work, I thought it would take me to the first randomList ancestor of listitem parent
../ancestor::randomList[1][@listitemPrefix='pf01']
Thanks for any help!
    Try: ../randomList/@listItemPrefix="pf01"
    Trevor Hendricks<">mailto:->
    Project Analyst -- Publication Systems
    Technical Communications, MS: 078
    cleccese1-VisitorAuthor
    Thank you, Trevor, that didn't work.
    Hi Caroline,
    Maybe ancestor::randomList[last()][@listitemPrefix='pf01']
    The ancestors are listed in reverse order, so you want the
    last one to get the outer one.
    Richard
    this works:
    ../ancestor::randomList[1][@listItemPrefix='pf01']
    Wait, what? That's what I had originally, but now it's working for some reason.
    Thanks, Richard, unfortunately didn't work. (There were two randomLists, easy to miss)
    How about:
    ./ancestor::randomlist[@listItemPrefix="pf01" and not(ancestor::randomlist)]
    So that would be looking for an ancestor that has the prefix, but also is
    not a child of other randomlists?
    On Wed, Mar 26, 2014 at 11:43 AM, Hendricks Trevor <
    > *Trevor Hendricks* <->
    > *m*: 920-226-2116
    > *p*: 920-457-4441; ext. 73571
    > *f*: 920-803-3939
    > *e*: -
    > *Experience gracious living with **Kohler
    > Math problems?? Call 1-800-10x(24+13)-(64-8y)/2+36x-17.
    > *From:* Caroline Leccese [
    > <randomlist>
    > <listitem>I am here<para>text</para></listitem>
    > </randomlist>
    > </para></listitem>
    > </randomlist>
    Hi Keith,
    Thanks for the reply, unfortunately it didn't work.
    This did: ../ancestor::randomList[1][@listItemPrefix='pf01']
