Jan 8, 2010 4:53 PM UTC
XSD Import
I am in the process of creating a new XSD Schema. I'm using the xsd:import option to import tags from other schemas we are currently using.
Namespace prefixes are: ipc, mm, wm
Everything is working great until i tried to insert a <mm:table> tag that is referenced in one of the imported schemas. It gives me the correct wrapper tag but when it hits the required <mm:tgroup> tag it gives me an internal error saying that that <ipc:tgroup> tag is out of context. It is reading the <ipc:tgroup> tag instead of the <mm:tgroup> tag. I have tried this using a different XML editor and it inserts the tags as expected.
Any help to this matter would be greatly appreciated.
sarah
    Jan 8, 2010 5:47 PM UTC
    I don't know very much about schemas, so others on list may have a better answer. In other words, I might be wrong. In a DTD, if you reference out to various, slightly-different entities for the CALS table model and the entity names are all the same, the DTD uses the first entity in the DTD and ignores the subsequent ones of the same name.
    Maybe something like this is happening in your case.
    Jan 8, 2010 5:56 PM UTC
    Thank you for your response and yes I believe that is correct.
    I have found some documentation showing the limitations/issues with the Xerces-C parser that Arbortext uses. If I take out the import option to the other schema then all works great.
    Was hoping someone would have some type of work around.
    Jan 8, 2010 6:45 PM UTC
    It isn't a simple calling of the file twice, something is also
    assigning a different namespace to the elements as well. Does the
    schema work properly in other tools? Can you make an instance and
    validate it outside of Arbortext and then see what Arbortext says to
    that. Something has got Arbortext trying to insert the right required
    tag but with the wrong namespace, seems like the schema is not correct.
    It would help to see the schema statements and the table definitions
    in particular to try and trouble shoot the problem.
    ..dan
    Jan 8, 2010 7:02 PM UTC
    Yes I am able to validate outside of Arbortext. Altova's XMLSpy has a built in parser and it works correctly with the correct namespace. The imported Schemas have been around for at least a year without any problems.
    Here import/namespace portion of the new schema:
    <xsd:schema xmlns="&lt;a" style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="http://anytown.mil/custom/doctypes/imm"">http://anytown.mil/custom/doctypes/imm" xmlns:ipc=" xmlns:mm="
    Jan 8, 2010 7:13 PM UTC
    Correction to Namespace at bottom
    Jan 8, 2010 7:24 PM UTC
    What does the table and tgroup information look like, that is where
    the namespace appears to cause problems.
    Do you have a test instance and does it validate with an mm:table and
    Jan 8, 2010 7:36 PM UTC
    Yes I can validate the mm:table and mm:tgroup tags just find out side of Arbortext. If I create an XML document outside of Arbortext with those tags in it and then open it in Arbortext it validates fine. It only appears to be a problem when I am inserting a mm:table tag inside an XML document in Arbortext.
    I think you are right about the bug.
    sarah
    18-Opal
    Jan 11, 2010 4:30 PM UTC
    Hi Sarah--
    To me, this sounds like it might be an issue with how your DCF is
    configured. Arbortext has lots of under-the-hood machinery to manage
    tables, and you may need to tweak your DCF to make it do what you want.
    Have you set up your tables as custom table models in your DCF file? If
    not, try doing that and see if it straightens out table handling for
    you. (Note: if you're using Styler for styling, you'll need to configure
    the custom table models in your Styler stylesheet too.) For guidance on
    how to do that, consult the online help, or look at the comments in
    $ARBORTEXT/doctypes/dcfdtd/dcfdtd.dtd.
    --Clay
    18-Opal
    Jan 11, 2010 5:00 PM UTC
    Are you referring to setup in Styler or setup in the DCF? If you mean
    Styler, you might need to double-check your DCF setup, make sure you
    have the hierarchy defined properly there. If the DCF isn't set up
    right, Styler won't pick up the hierarchy correctly to let you make the
    corresponding changes there.
    --C
    Jan 11, 2010 5:13 PM UTC
    Thanks for the info. Clay. I tried setting it up under the custom table model however it does not give me the option to define a mm:tgroup element so when I insert the mm:table tag it is telling me that the mm:row tag is out of context.
    Sarah
