XSL FO: Can you center sometimes?
This seems like such a stupid question but I've looked and looked and am getting nowhere...and I'm not that good with XSL FO.
Is there a way to test if the text is wider than the block and if so, change the inherited text-align=left to text-align=center if it is just one short sentence?
<xsl:template match="trim.para">
<fo:block font-family="sanserif" space-before.conditionality="discard" space-before.maximum="8pt" space-before.minimum="6pt" space-before.optimum="7pt" span="all">
<xsl:if test="@bullet" ==" yes&quot;=">
<xsl:text disable-output-escaping="no">•</xsl:text>
</xsl:if>
<xsl:apply-templates select="node()"/">
</fo:block>
</xsl:template>
John T. Jarrett
BAE Systems | Arbortext PE version 5.4 | LOGSA XSL-FO v 1.7
    18-Opal
    June 22, 2010
    Hi John-
    I don't know of a way to do exactly what you want, because the actual
    rendered font metrics aren't available for testing in the stylesheet.
    They don't get computed until things are rendered, which happens after
    XSLT transformation is done.
    But, you might be able to approximate what you want by examining the
    string length. It would look something like this:
    <fo:block font-family="sanserif" space-before.conditionality="discard"&lt;br"/>space-before.maximum="8pt" space-before.minimum="6pt"
    <xsl:if test="string-length(.)"> 80">
    <xsl:attribute name="text-align">center</xsl:attribute>
    </xsl:if>
    <xsl:text<br/>disable-output-escaping="no">•</xsl:text>
    </xsl:if>
    </fo:block>
    </xsl:template>
    HTH.
    --C
    John,
    I'm not completely clear on the effect you're after, but perhaps an
    appropriate combination of text-align and text-align-last might work?
    -Brandon Smiley Happy
    On Tue, Jun 22, 2010 at 11:41 AM, John Jarrett
    > sentence?
    > <fo:block font-family="sanserif" space-before.conditionality="discard"&lt;br"/>> space-before.maximum="8pt" space-before.minimum="6pt"
    > </xsl:if>
    > </fo:block>
    > </xsl:template>
    > Thanks,
    > John T. Jarrett
    > -----End Original Message-----
