Sep 22, 2011 6:44 PM UTC
XUI empty textbox value
Hi all,
I have a textbox in a XUI. There are cases when the textbox entry should be empty. That textbox string or empty value is populated to an attribute in the document xml. When deleting a string in the box the value returned to the change event listener is the last stored value. It seems to not recognize when the last character or a full string is deleted from the box, which should have created an empty textbox/value essentialy. Any recommendations? I'm using JavaScript with the XUI. I claim to not be a XUI or interface expert.
Thank you,
Bryan
    18-Opal
    Sep 22, 2011 8:19 PM UTC
    Hi Bryan-
    What event are you listening for? You might need to try listening for a
    different event type to catch the deletion of the last character.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    bbender4-ParticipantAuthor
    Sep 22, 2011 9:49 PM UTC
    Yep, I needed to add an event listener forDOMNodeRemovedFromDocument.
    Thanks!
