xui tabpanel: can I force one other than the first to be "selected" on window load?
I set an id on tabpanel and then try to;
dlgitem_set_focus($win, "mytabpanelid");
dlgitem_display($win, "mytabpanelid");
dlgitem_set($win, "mytabpanelid","ACTIVE",1);
dlgitem_set($win, "mytabpanelid","VISIBLE",1);
But no joy. The functions all return 1 but the first tabpanel in the series
is actually "selected" or displayed or "on top" if you know what I mean NOT
the one I'm attempting to call via its id.
Paul Nagai
    18-Opal
    December 10, 2010
    Hi Paul-
    Try setting focus to a control *on* the tabpanel rather than the panel
    itself.
    --Clay
    Paul,
    If the id of the tabbox is "tabbox" and you want to select the second
    panel, try dlgitem_set_value(win, 'tabbox', 2);
    Yes, I know that this is hard to figure out.
    Tung
    naglists1-VisitorAuthor
    dlgitem_set($clay,"beer","ACTIVE");
    That did it. Thanks!
    All of the sudden, I've got three choices. Thanks again, you rock!
    dlgitem_set(win, 'tabbox','VALUE',2);
    dlgitem_set_value(win, 'tabbox',2);
    dlgitem_set_focus(win,'controlontabratherthanthetabitself');
    Help on dlgitem_set_value states it is equivalent the the first example
    above.
    18-Opal
    December 10, 2010
