zip files updates to the custom
I want to know more about using the .zip file update to the custom folder.
I want to make it so my users can pull the .zip file and allow it update
the custom directories.
any guidance?
d
    18-Opal
    October 1, 2013
    Hi Douglas--
    There's pretty good documentation on this feature in the help center. Search for "zipped customizations" and you should be able to find everything you need.
    You can also check out a blog post I wrote about the subject a while back, which summarizes some of the advantages of distributing zipped customizations:
    Read the instructions in the Deployment kit that matches the version you are using. I believe that you can download it from the same page you get the Arbortext updates.
    -Andy
    Andy Esslinger LM Aero - Tech Order Data
    (817) 279-0442 1 Lockheed Blvd, MZ 4285
    (817) 777 3047 Fort Worth, TX 76108-3916
    [Title: Integrated Fighter Group]
