APP 11.1 M030 available for download
Key Functional Highlights
  • Debugger improvements
    • Additional controls – page up/down, run current script, reformat, save
    • Manage tags – create, rename, change type, delete
    • Tabbed tag editor – open multiple tags at once
    • Improved console – JavaScript and formatting errors, user log
  • Opacity
    • PDF only
    • Set opacity on frames, text, named colours, rules
  • Basic U3D support
    • Use a U3D graphic inline or in a frame
    • Select view to use when output
  • APP Enterprise replacement with Publishing Engine
    • XML activation file format – takes existing scripts, also allows other scripts, checks for input and output files
    • PE f=app request type – input is activation file, handed off to APP to be run, can be queued
    • APP generates HTML response for PE
  • Line numbering
    • Apply line numbering to frames
    • Set properties – location, offset, font, colour, number sequence
Documentation
Download
PTC Software download site
