主干条目可以筛选分支变化,这个变化来自哪些分支
用户创建了10个working-set,希望在主干上可以做和分支关系的筛选。比如:想筛选那些条目在分支1和分支2上都有修改,那些条目在分支3、分支4、分支5上都有修改
Catalina
Community Moderator
April 14, 2025
Hi @源段_10897294
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • What specific criteria are you using to create the 10 working-sets?
  • How are branches identified in your system? Are they labelled with specific names or numbers?
  • Have you already implemented any filtering mechanisms, or are you starting from scratch?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Moderator
Geoffrey Clemm
Google Translation:  The user has created 10 working-sets and hopes to filter the relationship between the trunk and the branches. For example, he wants to filter the items that have been modified on both branches 1 and 2, and the items that have been modified on branches 3, 4, and 5.
I will assume that "branch" and "working-set" mean the same thing in this question.
A few questions:
What is the use case for performing this filter/query?
Were all of the working-sets created from the Default working-set (i.e. is the parent of the created working-sets always the Default working-set)?
Does "being modified on a branch" mean "the user explicitly edited that item in that branch", or "the version selected on that branch is different from the version selected by the Default working-set"?
