Add/Remove Test Cases After Test Run Start
Hi Team,
as per the PTC codebeamer articles,
Test cases can be added to or removed from a Test Run only under the following conditions only:
For a Regular Test Run when the status is “Ready for Execution”
For a Formal Test Run when the status is “To be Approved”
However, Customer requirement is need to add or remove the test cases from test run when the Test Run is "In progress" state or "Finished" when we are restarting the test run
is there any way to achieve this ?
please refer case details 18065754 for more information
Catalina
Community Manager
Hi ​@SY_10545985
Thank you for your post!
Please know that you make a reference to a case number but users will not have access to it and won't be able to get the insights you intend. If you need to share information from the case with other users here, please make sure not to include any proprietary and/or sensitive data,a s this is a public space.
Best regards,
Catalina | PTC Community Manager
Brian Kampling
​@SY_10545985 you will need to create a new test run. To be able to add or remove test cases from an in progress run would undermine the integrity of the test.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
