3-Newcomer
May 12, 2025 5:38 PM UTC
Adding items of specific baseline to a tracker via REST API
Is it possible to add a version of an item from a specific baseline to a tracker via the API?
The use case is: a test case tracker with multiple baselines -> create a test set for a specific test case tracker version.
Catalina
Community Manager
May 21, 2025 7:25 AM UTC
Hi @VA_11837938
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
