Allow the storage of multiple specialized Office templates within the project settings instead of a single default.
Enable a selection menu during export so the correct .docx layout can be applied based on the tracker type.
Justification: This is required to automate standardized document generation for different V-cycle phases and ensure compliance with various reporting formats.
Brian Kampling
​@DA_12810717, could you post a screenshot of where you are looking? The ability to select and apply custom-defined templates is part of Codebeamer’s core functionality.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
