3-Newcomer
Baseline creation and update
1. Inconsistent baseline selection behavior:
When creating a new Working Set, users have the option to add trackers with a specific baseline.
However, when updating an existing Working Set by adding new trackers, the option to select a baseline is not available.
Providing the same baseline selection menu during updates would improve usability; otherwise, users must manually select a baseline for each tracker, which is time‑consuming.
2. Baseline selection is lost when navigating back:
After users select trackers with a specific baseline and move to the next step, a summary of the selections is displayed.
If the user goes back to the previous step, the tool resets all baseline selections to HEAD.
As a result, users must again manually reselect the required baseline for each tracker, causing unnecessary repetition and frustration.
Brian Kampling
Hi ​@AK_14431022
Could you share what version of Codebeamer you are one? As of 3.2 working sets were replaced with streams, so it would be helpful to know what version you are on.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
