Case Studies of Codebeamer for Embedded AI Model Development in Automotive Software
Hello everyone,
I would like to ask if anyone can share case studies or examples where Codebeamer has been used for AI model development in automotive software, particularly for AI models that are embedded in actual products.
We are considering a configuration along the following lines:
  • Codebeamer
  • Experiment management tools (e.g., Weights & Biases, MLflow)
  • Git-based repository (e.g., JFrog)
To clarify, we are not referring to AI models used in development support tools, but rather to AI models that are part of the delivered automotive product itself.
If you have any relevant experiences, best practices, or references, we would greatly appreciate your insights.
Thank you very much in advance for your time and support.
Emeritus
Hi ​@NM_4198246,
Thank you for your question.
Vivek N
Community Moderation Team
I would like to add some supplementary information and share a hypothesis.
As described in the following article, it appears possible to establish a mechanism in which the training process (experiments) of AI models and their resulting artifacts are managed using MLflow and JFrog Artifactory:
https://jfrog.com/blog/jfrog-plugin-for-mlflow/
However, I believe that this tool integration lacks certain key aspects, such as:
  • How the target scope of the training process (experiments) is defined, and
  • Whether the defined targets have already been trained or not.
Based on this, I speculate that it may be possible to address these gaps by integrating Codebeamer with MLflow and JFrog Artifactory, enabling:
  • Management of requirements for training targets,
  • Definition of training targets, and
  • Tracking of the achievement status of training processes (experiments).
Furthermore, I also hypothesize that the above process and its management could be conceptually similar to safety assurance under SOTIF.
With these considerations in mind, I would greatly appreciate it if anyone could share insights or case studies regarding effective use of Codebeamer in AI model development.
​@vnamboodheri
Thank you for your advice.
Brian Kampling
Hi ​@NM_4198246
It is possible that you are the first to have thought of this. Do you have the ability to run an experiment and be the one with the first case study? If you do, and you need help, feel free to keep using this topic as a thread to ask questions and we can try to support you the best we are able.
Brian
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
Hello ​@BKampling_SAI ,
Thank you for your encouragement and for offering your support.
I agree that there may be an opportunity here to explore a first case study, and I am currently assessing the feasibility of conducting an internal experiment to validate this approach with my customer. If we proceed, I would greatly appreciate your guidance and may follow up with specific questions as we progress.
I will continue using this thread to share updates and seek your insights where needed.
Thanks again for your support.
