Jun 20, 2025 11:05 AM UTC
Codebeamer 3.0.0.2 is not accessible from any Public Network
We need to expose the installed Codebeamer from outside of system , from any Public network so that we can integrate codebeamer with any Application like Git, Jira, Windchill etc.
pshashipreetham
Jul 24, 2025 2:35 PM UTC
We had a similar requirement to make Codebeamer 3.0.0.2 accessible from public networks so that it can integrate with tools like Git, Jira, Windchill, etc. Here's what worked for us:
  1. Reverse Proxy Setup:
    We used Nginx on a public-facing VM to route traffic to the internal Codebeamer instance running on port 8080.
  2. DNS & Static IP:
    Assigned a public static IP and mapped a DNS (e.g., cb.company.com) to it.
  3. HTTPS Configuration:
    Enabled SSL using Let’s Encrypt for secure access over HTTPS.
  4. Firewall Rules:
    Opened only port 443 (HTTPS) to the world. All other ports are blocked.
  5. Security Measures:
    • Restricted access via IP allow-list (optional).
    • Enforced authentication and strong password policy.
    • Enabled logging and monitoring at the proxy layer.
Once exposed, we successfully connected Codebeamer with external tools via APIs and webhooks.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Community Moderator
Aug 11, 2025 9:27 PM UTC
Hi @TD_725989,
Anurag
