StickyQuestion
Codebeamer 3.3.1.0 has released!
Dear Customers -
Codebeamer releases follow a six-month release cadence. PTC across the board for all products is switching its release cycle to go for a common naming convention and calendar schedule. Which would mean, there isn’t a Codebeamer release in December’26. However, we understand the importance of these releases for your internal roadmaps and project deliveries. The ALM team decided to branch off and release critical functionality ahead as a one-off release model in the form of Codebeamer 3.2.1.0 and Codebeamer 3.3.1.0 that have released in November’26. The next releases you should watch-out for are Codebeamer AI 1.3 followed by Codebeamer 2027.0 & Codebeamer AI 2027.0
Key Highlights of Codebeamer 3.3.1.0
  • Configuration Management Improvements - Making configuration reuse and stream merging more reliable.
    Enhancements to configuration management reduce manual effort and improve consistency when copying configurations and merging streams.
    • Cross-project reference handling: Automatically updates applicable references when copying process configurations to target streams.
    • Tracker layout validation: Prevents incompatible tracker layouts from being merged.
    • Hierarchy preservation: Maintains child-item hierarchies when parent items are missing from the target stream.
    • Conflict management: Automatically removes qualifying no-change conflicts, reducing unnecessary manual resolution.
  • Digital Thread Integration Enhancements - Strengthening cross-tool traceability and interoperability.
    Codebeamer 3.3.1 expands OSLC-based Digital Product Traceability (DPT) capabilities, improving integration with IBM Engineering Test Management (ETM), Capella, and other engineering tools.
    • IBM ETM integration: Project-level mapping improves reverse lookup performance and visibility of externally linked items and OIDC / OAuth 2.0 support secures the integration and system.
    • Capella integration: Native OSLC server configuration and reverse lookup support enable improved traceability between systems engineering and ALM artifacts.
    • Improved interoperability: Default resource types and pagination support enhance OSLC resource exchange.
  • Task and Change Collaboration - Enabling Codebeamer to drive coordinated change management with Windchill.
    New Task and Change Collaboration capabilities connect ALM and PLM change processes, enabling teams to initiate changes in Codebeamer and seamlessly coordinate them with related changes in Windchill.
    • Eliminate manual handoffs and accelerate execution by automatically generating, linking, and synchronizing product changes between Codebeamer and Windchill.
    • Drive better business outcomes through real-time availability of updates, improving data quality, reducing rework, shortening resolution cycles, and enabling organizations to scale collaboration across engineering disciplines.
  • Product Relationship Explorer Integration - Improving visibility across engineering and product data.
    Codebeamer 3.3.1 introduces integration with Product Relationship Explorer (PRE), extending visibility into relationships between ALM and PLM artifacts.
    • Visually explores children, associations and relationships between Codebeamer tracker items.
    • Visually explores upstream and downstream relationships between Codebeamer tracker items and Windchill Parts.
    • Improves visibility into dependencies across product development data.
    • Provides configurable integration settings for enabling PRE access directly from Codebeamer.
  • Security Monitoring and Auditability -Improving security visibility through SIEM integration.
    Codebeamer 3.3.1 introduces dedicated security event logging to support enterprise security monitoring and investigation.
    • Generates security-relevant events in a dedicated log file.
    • Uses the Elastic Common Schema (ECS) format for structured logging.
  • Platform Reliability and Integration Improvements - Strengthening operational reliability and data exchange.
    • Improved ReqIF imports: Enhances handling of unsupported XHTML structures.
    • DOORS Bridge usability: Adds an option to remember login credentials during imports.
 Documentation
Download
