Codebeamer 3.3 - Review Hub - Insufficient list of filters
What product version are you running?
Codebeamer 3.3
Describe the Problem
To support a collaborative peer-review in industry company, the current list of filters to search items is insufficient.
A more detailed breakdown by business unit, by domain, by reviewer is needed.
Are you using a work around?
Currently, with the proposed list, the review process takes longer because each reviewer must manually search for the requirements that are most relevant to them.
What business value would your suggestion represent for your organization?
Make the review process more efficient and faster
Do you have an idea how this problem could be solved?
Extend the list in order to get the capability to select a reviewer, a team.
