Codebeamer Community Challenge November 2026 – Codebeamer Coffee Maker!
The challenge is to take one of these specifications through the MBSE path using Codebeamer tools. For example, if you took “Safe in My Kitchen, you could 1) break down safety requirements at the system level 2) implementation of these requirements 3) test the implementation 4) integrate the solution back into the full machine 5) Testing each level of integration (probably 1 or 2 realistically) 6) verifying it meets requirements for safety accreditation for commercial sale.
Please show how it was configured, why you chose the way you did it, what workflow you chose to utilize, if it’s a variation from a MBSE norm, why you chose to do it that way.
This Quarter’s Challenge:
We will be using a coffee machine as a project.
Start with the following customer requirements:
| Quiet mornings |
As an early riser, I want the machine quiet enough to use without waking the rest of the household. |
| Milk drinks at home | As a latte and cappuccino drinker, I want to make milk-based drinks easily at home. |
| Fresh grounds built in | As a coffee enthusiast, I want freshly ground coffee without needing a separate grinder on my counter. |
| Doesn't waste energy | As an energy-conscious user, I want the machine to use very little power when I'm not using it, so leaving it on doesn't cost me much. |
| Know what it's doing | As a user, I want to always know what the machine is doing and what to do when something goes wrong, so I'm never left guessing. |
| Easy to maintain | As an owner, I want cleaning and upkeep to be simple and to be reminded when it is needed, so the machine keeps working well for years. |
| Safe in my kitchen | As a household with kids and pets, I want a machine that is safe to use and leave plugged in, so I never have to worry about burns or hazards. |
| Ready when I am | As a busy morning user, I want the machine ready to use within a few minutes of turning it on, so it fits into my routine. |
| Café-quality espresso | As a home barista, I want espresso that tastes as good as what I get at a café, so I don't have to go out for a good shot. |
