7-Bedrock
CodeBeamer Export Should Render UI View Instead of Markup
Issue Details
  • Create or import an item with the description field set as Wiki format, including elements like:
    • Links
    • Bold / Italic text
    • Strikethrough formatting
  • After saving, the content is displayed correctly in the UI in a readable, formatted way without exposing markup syntax.
  • However, when exporting the same item using the default export template:
    • The description is exported in raw markup language instead of the formatted view.
  • This creates difficulty for users who expect exported content to match what they see in the UI.
Current Resolution
  • A workaround exists using Groovy scripting to export the formatted description content.
  • However, this is not a standard or user-friendly solution and requires additional effort and customization.
Proposal
  • Enhance the export functionality to output content as rendered in the UI (formatted view) instead of raw markup.
  • Provide an option in export settings to choose between:
    • Raw markup format
    • Rendered (UI-equivalent) format
Benefits
  • Improved usability: Exported data matches what users see in the UI, reducing confusion.
  • Better readability: Eliminates the need to interpret markup syntax in exported files.
  • Reduced dependency on scripting: Removes the need for Groovy-based custom solutions.
  • Consistency: Aligns export output with UI representation.
  • Enhanced productivity: Users can directly use exported content for reporting and review purposes.
you can export to excel the wiki markup converted to hmtl (limited by the out of the box excel formatting capabilities) using https://nangasystems.com/en/produkte/codebeamer_export_services
