8-Gravel
November 20, 2024
Codebeamer review hub error
  • November 20, 2024
  • 2 replies
  • 1041 views
We are not able to access review hub on our instance of codebeamer and are getting the below error messages:
"Http failure response for http://bocodebeamer:8080/cb/api/configuration/integrationConfig: 429 OK"
Error: Too Many Requests.
Due to this, we can't start any reviews or use the functionality.  Has anyone else encountered this that can support?
Best answer by IvyZhuang
Hello @MeganB_T
Please check the article https://www.ptc.com/en/support/article/CS429634. The issue can be solved by disabling apiThrottling
Best regards,
Ivy
IvyZhuang17-PeridotAnswer
Hello @MeganB_T
Best regards,
Ivy
Community Moderator
November 28, 2024
Hello @MeganB_T
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
