3-Newcomer
Common ID
We are migrating from DOORS to Codebeamer, and are looking for a way to view and display a software requirement’s Common ID (as described here: About the Common ID and Local ID). This would be useful for us because the Common ID does not change from stream to stream, so it provides a persistent stream-independent ID that we can use to refer to requirements. Where can we view a requirement object’s Common ID, and can we display it as a tracker field?
    Geoffrey Clemm
    Create a custom computed field, and set the computation to be: commonItemId
