Jul 30, 2024 9:20 AM UTC
create/edit Test Case
Hello all,
we are not able to create or edit Test Cases.
Always get error:
Transaction rolled back because it has been marked as rollback-only
Tried bellow  article CS416551 and didn't help:
Article - CS416551 - Transaction rolled back because it has been marked as rollback-only when modifying a Test Case in Codebeamer (ptc.com)
Interesting is that creation or edit works if "Document Edit View" is active but not in "Table View or Document View".
thank you
alfonso_cAnswer
Aug 1, 2024 6:35 AM UTC
Hello @MM_10991077, This behavior seems unexpected and inconsistent, please raise a Support Ticket so that we can analyze it further. In the ticket, please provide:
Thanks in advance
Catalina
Community Manager
Jul 31, 2024 2:21 PM UTC
Hi @MM_10991077,
Thank you for your question!
Thank you for your participation!
Best regards,
Catalina
PTC Community Moderator
Catalina | PTC Community Manager
alfonso_c14-AlexandriteAnswer
Thanks in advance
Aug 2, 2024 12:08 PM UTC
Hello Alfonso,
thank you for your reply.
Regarding a project template export.
What data will be exported ?
There might be a problem for project owner to share sensible data.
thank you
Aug 6, 2024 12:01 PM UTC
Dear @MM_10991077 ,
when you export your project, exclude the "work items", "reports" and "wiki pages".  That way, we receive only the configuration and no data.
See more details on the following page: https://codebeamer.com/cb/wiki/7060303
Alternative solution can be that you export your project and import the same. You can check what data you'll share with us.
