Oct 22, 2024 7:23 AM UTC
excel file edit via office throw error: excel couldn't find file
Hello all,
user wants to edit excel file document using office and gets below error:
Office editor is installed ver. 2.0
Delete browser cache is not helping now (it helped one day ago).
Tried on Edge and Chrome browser.
No error visible in Codebeamer log.
any idea?
update:
after check of cboffice_launcher.log in C:\Users\<username>\AppData\Local\Temp\
I have realized that ":" is missing after https
22-Oct-24 9:44:33 AM - ----------------------------------
22-Oct-24 9:44:33 AM - Starting cbOffice Launcher - 1.03
22-Oct-24 9:44:33 AM - Original url: cboffice://https//Server-Name/cb/officeedit/C4iKYBjM8zG4bQPkoyks2fekME6LC0JlqSdZTboB7cQ/Trigger%5FMessages%5Ffor%5FInbound.xls
22-Oct-24 9:44:33 AM - Service Url: https//Server-Name/cb/officeedit/C4iKYBjM8zG4bQPkoyks2fekME6LC0JlqSdZTboB7cQ/Trigger%5FMessages%5Ffor%5FInbound.xls
22-Oct-24 9:44:33 AM - File type: .xls
22-Oct-24 9:44:33 AM - Command: %comspec% /c assoc .xls > "C:\Users\userXYZ\AppData\Local\Temp\radC7736.tmp"
22-Oct-24 9:44:33 AM - Command: %comspec% /c ftype Excel.Sheet.8 > "C:\Users\userXYZ\AppData\Local\Temp\radA7F62.tmp"
22-Oct-24 9:44:33 AM - Associated Program: C:\Program Files (x86)\Microsoft Office\Root\Office16\EXCEL.EXE
22-Oct-24 9:44:33 AM - Start associated command: %comspec% /c "C:\Program Files (x86)\Microsoft Office\Root\Office16\EXCEL.EXE" https//Server-Name/cb/officeedit/C4iKYBjM8zG4bQPkoyks2fekME6LC0JlqSdZTboB7cQ/Trigger%5FMessages%5Ffor%5FInbound.xls
any idea how to fix it ?
thank you
alfonso_cAnswer
Oct 31, 2024 9:13 AM UTC
Oct 22, 2024 10:36 AM UTC
Hello @MM_10991077 , I can reproduce a similar issue on MS Edge: Word document opens, but it's blank. Local log:
10/22/2024 12:21:31 PM - ----------------------------------
10/22/2024 12:21:31 PM - Starting cbOffice Launcher - 1.03
10/22/2024 12:21:31 PM - Original url: cboffice://http//localhost:8080/officeedit/ciFjBQjnt6uPxTa%5Fv2kZhLwneoH2LPxor7bYp49dfBc/issue-desc-1099.docx
10/22/2024 12:21:31 PM - Service Url: http//localhost:8080/officeedit/ciFjBQjnt6uPxTa%5Fv2kZhLwneoH2LPxor7bYp49dfBc/issue-desc-1099.docx
10/22/2024 12:21:31 PM - File type: .docx
10/22/2024 12:21:31 PM - Command: %comspec% /c assoc .docx > "C:\Users\acrisci\AppData\Local\Temp\radC59CA.tmp"
10/22/2024 12:21:31 PM - Command: %comspec% /c ftype Word.Document.12 > "C:\Users\acrisci\AppData\Local\Temp\radBA0D6.tmp"
10/22/2024 12:21:31 PM - Associated Program: C:\Program Files\Microsoft Office\Root\Office16\WINWORD.EXE
10/22/2024 12:21:31 PM - Start associated command: %comspec% /c "C:\Program Files\Microsoft Office\Root\Office16\WINWORD.EXE" http//localhost:8080/officeedit/ciFjBQjnt6uPxTa%5Fv2kZhLwneoH2LPxor7bYp49dfBc/issue-desc-1099.docx
The Start associated command: %comspec% /c "C:\Program Files\Microsoft Office\Root\Office16\WINWORD.EXE" http//localhost:8080/ does not look correct.
I tested on Mozilla Firefox and Google Chrome and it worked well, the last line also correctly produced http:// instead of http//. I continue to investigate and will post updates if I have any. In the meantime, please feel free to raise a support ticket to get further assistance.
3-Newcomer
Oct 25, 2024 11:07 AM UTC
Hi All,
I think I found a solution for the problem the URL seems to be wrong.
I updated the "C:\Program Files\codebeamer Office Launcher\cboffice_launcher.vbs" file adding the following 2 lines.
to line 30 and 31
url = Replace(url, "https//", "https://")
url = Replace(url, "https/", "https://")
After this change office_launcher started working as before.
Kind Regards,
 Peter
alfonso_c14-AlexandriteAnswer
Thanks for sharing this possible approach, I can see this has been recently reported to our Engineering Team, more information is at this page: MS Excel file opened with "Edit Via Office" from Documents tab shows error "'Sorry, we couldn't find https/<hostname>:<port>/cb/officeedit/<some_hashcode>/<filename>.xlsx.Is it possible it was moved, renamed or deleted?'"
Oct 25, 2024 9:38 AM UTC
Also on our system, recently users report same error that file cannot be found.
