7-Bedrock
Exporting the text field content as viewable in UI
Issue summary: In current CB v2.2.x, CB exporting the content as it is in Markup type. But in UI is clean to see the content without any markup contents
Issue Details:
  1. Create or Import an item with description as Wiki with some links or bold or italic or strikethough etc, and save it
  2. Now in UI as a user, we can see the content clearly without any markup languages.
  3. But when we export the same item in default template, i could see description exported in markup language.
Current Resolution: Using groovy, we can export the description content but it is 2nd way.
Suggestion: If Codebeamer exports same as viewable in UI, it will be very useful
Community Moderator
Hi ​@Thamil_AST,
Thank you for your question.
Anurag
Brian Kampling
Are you using the Simple Excel Export or the Round-Trip Excel Export?
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
7-Bedrock
I am doing simple export. To avoid special characters, i am using template to get the content same as in Codebeamer UI
Brian Kampling
That is exactly the approach you should be taking. Some folks want the raw markup data, so filtering that out by default would eliminate that option.
