7-Bedrock
Feb 17, 2025 4:58 PM UTC
Filter view or field filter view inheritance
Hi all, I'm trying to provide with my template filter view that will be inherited by other project, my question is if it's possible ? Look like it's not working, maybe it's not available option?
7-Bedrock
May 30, 2025 7:52 AM UTC
Question was related with search view filter for reference field, for now I'm closing this question as we are migrating to 2.2 CB and later we will verify that once again.
Feb 26, 2025 3:54 PM UTC
Hi @DP_10914663 ,
I've checked this function and it worked for me.
I've created a status filter in a tracker of my template project and saved it as Public View.
Created a new project using the prior one as template.
In the same tracker the view is visible and useable.
What are the steps you used to create the filter? Which version of Codebeamer do you use?
DP_109146637-BedrockAuthorAnswer
7-Bedrock
