3-Newcomer
Filtering options for rerunning test runs shall be expanded
The options for rerunning test cases shall have the filtering options extended. Currently we are able to only test result in case of the test case pick window. We would like to have the following filtering capabilities added:
  • Previously not executed test cases
  • Filtering by priority
  • Failed test cases where the associated defect status is Implemented
Brian Kampling
​@YL_11098911 could you provide a little more context as to your testing process? I’m not sure what you mean by re-running test cases that have not yet been executed. Also, you would want to create new test runs for test cases associated with fixed defects to show the traceability to the resolved defect.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
