7-Bedrock
Jul 3, 2024 9:24 AM UTC
git integration with codebeamer
Iam Successfully able to Integrate Git with Code beamer by adding Webhooks but when I'm committing the changes or committing new files every time I have to create a new webhook as it is not showing in the code beamer. Can you suggest some workarounds to resolve this issue
Jul 3, 2024 12:02 PM UTC
The wiki page for GitHub Webhook integration provides details on how to compose the webhook payload URL: Configure GitHub webhook (codebeamer.com)
  • Payload URL: <codebeamer_url>/rest/scm/github/<project_id>
    Where codebeamer_url is the url of your codebeamer and project_id is the id of your project where the GitHub repository will belong to after the first webhook execution
  • You will need a <codebeamer_url>, which can be created as a permanent internet facing url (visible from the public Internet) hosted on a server or via tunneling software
Jul 3, 2024 10:34 AM UTC
Hi MS_10920745,
Could you provide more details as to what type of repository you are using?
Is this a GitHub or GitLab integration? Is it an external HTTPS Git repository?
Thank you!
7-Bedrock
Jul 3, 2024 11:52 AM UTC
hii
I’m using github
