7-Bedrock
How to develop custom scripts for Codebeamer?
As system and project administrator in Codebeamer I need to develop scripts to fulfil the requirements of my users, when the out-of-box functionality of Codebeamer is not sufficient.
F.e. I want to prevent having multiple downstream references from items within the same tracker.
Coming from RVS Trigger Scripts debugging was a pain, but there were extensive JavaDocs available.
With Codebeamer all I could find was some examples (https://support.ptc.com/help/codebeamer/r2.1/en/index.html#page/codebeamer/developers_guide/649989.html#), but no documentation which objects or classes are available and how to use them.
How do you actually develop custom scripts?
Am I supposed to just guess which Beans are available?
Catalina
Community Manager
Hi @MS_9990422
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
I see that this thread hasn't received a reply.
We're also interested in this documentation and cannot find any in the PTC articles/helper or reference documents.
Is there any technical documentation for Codebeamer that explicitly lists the methods to use, similar to the RV&S Javadoc ?
The goal is to find out which beans are available and which methods to use. RV&S has comprehensive technical documentation on triggers, but I don't see it on Codebeamer.
Best regards,
Alex
