7-Bedrock
July 21, 2025
How to obtain Client ID and Client Secret for OpenID (OAuth 2.0) in Codebeamer – OpenID already enab
Hi Team,
We are currently working on integrating Codebeamer with Cameo using OSLC, and for authentication, we plan to use OAuth 2.0 via OpenID Connect.
We have already enabled OpenID in our Codebeamer instance and enforced OAuth2 login under:
System Admin → OpenID Configuration.
However, we are missing critical configuration details to complete the setup:
 What we need help with:
  1. How can we get the following for our Codebeamer OAuth Client?
    • Client ID
    • Client Secret
    • Client Name
  2. Is there a specific place in the Codebeamer UI or backend where we can register a new OAuth client and generate these credentials?
  3. Do we need to manually register Codebeamer as a client application on an external OpenID Provider (like Google, Azure, or internal SSO)?
  4. Where can we find or configure the following values if we use PTC's internal OpenID?
    • authorizationEndpointUri
    • tokenEndpointUri
    • userinfoEndpoint
    • jwksUri
 Our Setup:
We want to use these credentials in our OSLC integration with Cameo, where the Codebeamer server will act as a secured OAuth2/OpenID client.
Any guidance, documentation links, or admin-level instructions would be greatly appreciated.
Thanks in advance!
Brian Kampling
Hi @AL_12731379
You will need to set up an authorization server to generate those for you.
Follow the steps in this documentation to get started: https://support.ptc.com/help/codebeamer/r2.2/en/index.html#page/codebeamer/install_guide/5376270.html
Brian Kampling - Source Allies
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
Community Moderator
July 28, 2025
Hello @AL_12731379,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
