6-Contributor
Individual Test Run Export
Ability to export “individual test runs”(only child runs) from Codebeamer. Currently, only parent test runs can be exported.
TJThielen
8-Gravel
If your goal is to export only the test runs that are children, you can filter the Test Runs view by Parent: not empty
That will filter out any test runs that do not have a parent (so all the top-level Test Runs), and from there you can perform the export. Does this cover what you’re wanting, or is there something else you’re doing and expecting?
