Mar 6, 2025 9:12 AM UTC
Inquire about applying the user custom.jsp file
Hi members I want to apply the .jsp page that the user will use as custom on the codebeamer, but I'm going to proceed with it in the following way
1. Create a views folder in the C:\CB-2.2.2\tomcat\webapps\cb\WEB-INF\ path to register a .jsp file to that folder
2. Deploy code to use as a custom controller in the C:\\CB-2.0.2\tomcat\\webapps\cb\\WEB-INF\\lib folder as a JAR file
3. Add settings for my-applicationContext.xm in /tomcat/conf/server.xml and /tomcat/webapps/cb/WEB-INF/classes
If you call the .jsp file through the controller (for example, http://localhost:80/cb/custom/myCreateProject) in the browser, you will get a 404 error. You will be wondering how to set up the class file to be used as the controller and where to locate and use the .jsp file.
JoeD_SAIAnswer
7-Bedrock
Mar 6, 2025 7:54 PM UTC
You should be able to see some success with some small changes.
Ensure your controller is in the com.intland.codebeamer.controller package.
This controller implementation was working in Codebeamer. It appears that the ".spr" extension in the mapping is critical, removing it caused the same behavior you described. This was compiled and uploaded as a jar to tomcat/webapps/cb/WEB-INF/lib.
@GetMapping({"/helloWorld.spr"})
public ModelAndView helloWorld(HttpServletRequest request) {
 if (!ControllerUtils.isAjaxRequest(request) && !UserAgent.get(request).isRobot()) {
 return new ModelAndView("helloWorld.jsp");
 } else {
 throw new ResponseStatusException(HttpStatus.FORBIDDEN);
 Then this jsp content was uploaded to /tomcat/webapps/cb/
<html>
<body>
 Hello! The time is now <%= new java.util.Date() %>
</body>
</html>
No changes to the application context configuration was needed.
JoeD_SAI7-BedrockAnswer
7-Bedrock
 } else {
<html>
<body>
</body>
</html>
Catalina
Community Manager
Mar 12, 2025 8:45 AM UTC
Hi @IL_12699072,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
