Nov 7, 2024 7:45 AM UTC
Inquiry on Updating Tracker Item Field Values
I would like to add a requirement item to the Verifies field, as shown in the attached example. To perform this “Add” action via the API, I used the items/{item_id} PUT API with the following body:
{ "subjects": [ { "id": {req_item_id}, "name": "Supports VOR(32 or 8kbit)", "type": "TrackerItemReference" } ] }
However, when I sent the /v3/items/{item_id} PUT request, I received an error: "State transition from New to -- is not defined for [HARDTC-{item_id}]".
Could you let me know if there is something I am doing incorrectly, or if I should be using a different API for this operation?
Thank you for your assistance.
CatnipAnswer
Nov 18, 2024 2:06 PM UTC
Hi @현전_11616217
Hi @현전_11616217 ,
First I would suggest that  you use  GET /api/v3/items/{itemid}/fields to obtain the ID of the "Verifies" field.
Once you know the ID,  you can proceed with the second step, using  PUT /api/v3/items/{itemid}/fields endpoint to update the "Verifies" field with the necessary requirement item.
This is an example with step by step examples:
  1. Use GET /api/v3/items/{itemid}/fields, to find information about the referenced field
Here is an example where I already have an item added in the Verifies field:
 2. With the information about the reference field, you can go to the next endpoint PUT api/v3/items/{itemID}/fields and update the Verifies field
       Json body should look like this:
"fieldValues": [
"fieldId": 17,
"name": "Verifies",
"values": [
"id": 1074,
"name": "srs3",
"type": "TrackerItemReference",
"angularIcon": "lightbulb",
"iconColor": "#b31317",
"propagateSuspects": false,
"trackerKey": "SRS",
"trackerTypeId": 16,
"uri": "/issue/1074",
"referenceData": {
"suspectPropagation": "PROPAGATE"
"sharedFieldNames": [],
"type": "ChoiceFieldValue"
Let me know if this helped.
Catalina
Community Manager
Nov 12, 2024 11:29 AM UTC
Hi @현전_11616217
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
Catnip12-AmethystAnswer
Hi @현전_11616217
Hi @현전_11616217 ,
"fieldValues": [
"fieldId": 17,
"name": "Verifies",
"values": [
"id": 1074,
"name": "srs3",
"referenceData": {
Catalina
Community Manager
Nov 26, 2024 8:20 AM UTC
Hi @현전_11616217 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
