login with wrong password audit
does Codebeamer track attempts to log in with wrong user password?
I found only successful logins in System Admin -> Audit .
Domain users can be track in Active Directory but what about local users?
thank you
RiverSideAnswer
Hello @MM_10991077 ,
Unsuccessful login attempts of both LDAP and local users are logged in the cb.txt logfile.
Currently there is not UI solution to track these.
RiverSide12-AmethystAnswer
Community Moderator
June 13, 2024
Hello @MM_10991077,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
