Oct 25, 2024 9:14 AM UTC
Options to automate ReqIF Import
Hi!
We want to automate the ReqIF import process in Codebeamer. According to PTC Support, there is currently no API for this, so the only known option is through the "Import ReqIF" in the Trackers menu within the UI. Has anyone worked on automating ReqIF imports or found any possible workarounds? Thanks!
Catalina
Community Manager
Oct 29, 2024 2:38 PM UTC
Hi @Alexej_L,
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
Alexej_L10-MarbleAuthor
Nov 14, 2024 10:17 AM UTC
We have identified two potential options to automate the ReqIF import:
  1. As previously mentioned, using the "Import ReqIF" feature in the Trackers menu within the Codebeamer UI (with Selenium).
  2. Using a Java-based approach, where the Codebeamer jar is included as an external library in your Java project. The package com.intland.codebeamer.controller.reqif handles ReqIF.
Please note that both options are not officially supported or documented by PTC (based on a PTC Support statement).
Nov 15, 2024 8:07 AM UTC
Hi @Alexej_L
Please see the below article regarding the automation of ReqIF import.
Article - CS423273 - API to automate ReqIF import in Codebeamer
Nov 15, 2024 8:26 AM UTC
Hi @Catnip
Thank you! I’m aware of that case. PTC Support couldn’t specify the release or date when it would be available. Since the customer was not satisfied with such an undefined status, they asked us to explore workarounds. As a result, we conducted our own investigation, and I also reached out to the community for additional insights. 😉
