Jan 27, 2025 4:23 PM UTC
Problem after converting the database from MySQL to Posgres
We are currently using CB-2.1.0.5 with a MySQL database.
We want to migrate to PostgreSQL and are using the Migrator Tool via Docker Images to convert the database.
The conversion completes without any issues, but after updating the database in the configuration file and restarting CB, logging in either results in a blank screen or a 404 error.
What could be causing this issue?
Community Moderator
Feb 26, 2025 8:15 PM UTC
Hi @VM_11608121,
Thank you for your question.
Anurag
7-Bedrock
Apr 9, 2025 8:42 PM UTC
The logs should be a good place to start. This support article mentions where the logs should be located. It is still relevant for your version of Codebeamer.
https://www.ptc.com/en/support/article/CS409610?source=search
