6-Contributor
Rehosting In Codebeamer
How can we do rehosting in Codebeamer Applictaion ?
Brian Kampling
If you are moving from the same or similar Codebeamer versions, you can export and import projects. This could be done manually or via the API.
Brian Kampling | Source Allies Inc. | Systems Engineering Consultant
